[postgis-devel] [PostGIS] #1963: regress failure on pgsql regress test caused by ST_Segmentize (was: Windows buildbot regress failure on pgsql regress test)
PostGIS trac at osgeo.org
Thu Aug 23 00:20:20 PDT 2012
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.1.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Introduction of ST_Segmentize(geography,numeric) I suspect is the culprit
 here, so revised the regress.sql to accomodate
 Should be fixed at r10198
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1963#comment:2>
