[postgis-devel] [PostGIS] #1965: turkish locale breaks postgis
PostGIS trac at osgeo.org
Fri Aug 24 09:01:21 PDT 2012
 Reporter:  plq      |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.2
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by plq):
 plq at iskembe ~  $ psql -U postgres some_db
 psql (9.1.5)
 Type "help" for help.
 some_db=# select postgis_Full_version();
 NOTICE:  Function postgis_topology_scripts_installed() not found. Is
 topology support enabled and topology.sql installed?
 postgis_full_version
  POSTGIS="2.0.1 r9979" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.7.1, 23
 September 2009" GDAL="GDAL 1.9.1, released 2012/05/15" LIBXML="2.8.0"
 LIBJSON="UNKNOWN" RASTER
 (1 row)
 some_db=# select version();
                                                           version
  PostgreSQL 9.1.5 on x86_64-pc-linux-gnu, compiled by x86_64-pc-linux-gnu-
 gcc (Gentoo 4.6.3 p1.3, pie-0.5.2) 4.6.3, 64-bit
 (1 row)
 some_db=#
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1965#comment:1>
