[postgis-devel] [PostGIS] #1965: turkish locale breaks postgis
PostGIS trac at osgeo.org
Fri Aug 24 09:06:04 PDT 2012
 Reporter:  plq      |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.2
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by plq):
 I'm not sure whether they'd be relevant, but here are the cluster
 settings:
 The database cluster will be initialized with locales
   COLLATE:  C
   CTYPE:    en_US.utf8
   MESSAGES: C
   MONETARY: C
   NUMERIC:  C
   TIME:     C
 The default database encoding has accordingly been set to UTF8.
 The default text search configuration will be set to "english".
 fixing permissions on existing directory /home/postgresql/9.1/data ... ok
 creating subdirectories ... ok
 selecting default max_connections ... 100
 selecting default shared_buffers ... 24MB
 creating configuration files ... ok
 creating template1 database in /home/postgresql/9.1/data/base/1 ... ok
 initializing pg_authid ... ok
 initializing dependencies ... ok
 creating system views ... ok
 loading system objects' descriptions ... ok
 creating collations ... ok
 creating conversions ... ok
 creating dictionaries ... ok
 setting privileges on built-in objects ... ok
 creating information schema ... ok
 loading PL/pgSQL server-side language ... ok
 vacuuming database template1 ... ok
 copying template1 to template0 ... ok
 copying template1 to postgres ... ok
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1965#comment:3>
