[postgis-devel] [PostGIS] #1708: postgis_restore not converting ndims and srid constraints to st_...
PostGIS trac at osgeo.org
Fri Aug 24 09:47:29 PDT 2012
  Reporter:  robe                   |       Owner:  strk
      Type:  defect                 |      Status:  reopened
  Priority:  medium                 |   Milestone:  PostGIS 2.0.1
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:                         |    Keywords:  history
Comment(by robe):
 Okay i think it might be there inherited table tripping up the script
 because I found another table with no inheritance and non-standard named
 geometry columns and the constraints for those were correctly renamed.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1708#comment:6>
