[postgis-devel] [PostGIS] #1835: JDBC Link broken
PostGIS trac at osgeo.org
Fri Aug 24 22:11:52 PDT 2012
 Reporter:  janetzko    |       Owner:  robe
     Type:  defect      |      Status:  new
 Priority:  medium      |   Milestone:  Management 2.0
Component:  management  |     Version:  2.0.x
 Keywords:              |
Comment(by robe):
 Okay I looked into this and found a couple of issues.
 1) the generated file name I think has changed
 It seems that instead of postgis-2.0.1SVN.jar etc. is now called:
 http://www.postgis.org/download/postgis-jdbc-2.0.1SVN.jar
 for example
 2) I finally got my winjen buildbot to build the maven package, but it
 seems the pom.xml has the version number hard-coded in it and you would
 need the ant make file to put in the version config and presumably built
 the pom.xml as well. So why pom.xml is in the repo is confusing to me.
 So I had to manually change the version number in pom.xml
 Am I mistaken that we need ant to build the pom.xml which kind of seems to
 defeat the purpose of switching to maven.
 I'm a java newbie so I could be mistaken here in my assumptions
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1835#comment:5>
