[postgis-devel] [PostGIS] #2122: [raster] Real extent feature lost after metadata as views
Mateusz Loskot mateusz at loskot.net
Mon Dec 3 08:58:47 PST 2012
On 3 December 2012 16:36, Sandro Santilli <strk at keybit.net> wrote:
> On Mon, Dec 03, 2012 at 04:29:14PM +0000, Mateusz Loskot wrote:
>> On 3 December 2012 16:05, Sandro Santilli <strk at keybit.net> wrote:
>> > On Mon, Dec 03, 2012 at 03:13:00PM +0000, Mateusz Loskot wrote:
>> >> On 1 December 2012 16:03, Sandro Santilli <strk at keybit.net> wrote:
>> >> Despite technically possible tohandle, it would complicate things though.
>> >> Is actual blocksize < max_blocksize_x|y allowed only along the right and
>> >> the bottom edge?
>> > No, I think it should be allowed everywhere
>> Then, we no longer discuss blocking in a regular grid.
> It'd be a regular-constrained grid
I don't understand what you mean.
Constraint how?
>> > I guess GDAL could just ensure the same blocksize when reading the rasters.
>> > There's an ST_Resize function IIRC.
>> This is optimisation feature, cache feature, predictable memory constraint, etc.
> The max size constraint would still give you predictable memory.
> You should be more specific about the cache and optimisation parts.
I speak of GDAL metchanisms and notion of natural block.
>> The original issue of spatial extent remains unresolved.
> The original issue was that the raster file extent is lost on
> import, and this loss is only due to padding, no ?
Yes.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
