[postgis-devel] Regular raster blocking (was: Real extent feature lost after metadata as views)
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Fri Dec 7 08:19:23 PST 2012
But the third part of the definition stay longer, right?
"3) All rasters (or tiles) have their width equal to blocksize_x and their height equal to blocksize_y. Only right-most tiles can have their width smaller than max_blocksize_x and only bottom tiles can have their height smaller than max_blocksize_y. Only the right-most, bottom tile of a coverage can have its width smaller than max_blocksize_x AND its height smaller than max_blocksize_y."
Verbose but clear.
Pierre
> -----Original Message-----
> From: postgis-devel-bounces at lists.osgeo.org [mailto:postgis-devel-
> bounces at lists.osgeo.org] On Behalf Of Mateusz Loskot
> Sent: Friday, December 07, 2012 11:16 AM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Regular raster blocking (was: Real extent feature
> On 7 December 2012 15:33, Sandro Santilli <strk at keybit.net> wrote:
> > On Fri, Dec 07, 2012 at 01:25:32PM +0000, Mateusz Loskot wrote:
> >> On 6 December 2012 18:32, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> wrote:
> >> > The regular_blocking constraint for a raster coverage (or raster table) is set
> to TRUE if and only if the following conditions are fulfilled:
> >> > 1) All rasters (or tiles) have the same SRID, scale_x, scale_y, skew_x,
> skew_y, number of band and all the
> >> > corresponding bands (having the same band number) have the same pixel
> types and nodata values.
> >> > 2) All rasters (or tiles) have their upper left corners aligned on a grid defined
> by the upper left corner of the coverage (or table) global extent and the block
> sizes.
> >> I agree with all the three points. (I snipped the details).
> > Where's the exception to (3) gone ?
> > The one aimed at allowing no padding, which started this whole thread ?
> In the course of  discussion, we have decided what follows:
> 1) we allow tilesize < blocksize exception for tiles located in the
> last row and column
> of the tiled raster grid
> 2) thus, padding is no longer required
> 3) but, padding is allowed and optional, and left to the discretion of
> user loading data
> who is assumed to be aware about the resulting change in spatial extent.
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-devel
