[postgis-devel] [PostGIS] #2122: [raster] Real extent feature lost after metadata as views
PostGIS trac at osgeo.org
Fri Dec 7 09:39:54 PST 2012
 Reporter:  mloskot                                 |       Owner:  dustymugs
     Type:  defect                                  |      Status:  new
 Priority:  medium                                  |   Milestone:
Component:  raster                                  |     Version:  trunk
 Keywords:  regular blocking,raster,extent,padding  |
Comment(by mloskot):
 Here is the final proposal for the updated regular blocking specification
 proposed by Pierre after the course of lengthy discussion:
 [http://lists.osgeo.org/pipermail/postgis-devel/2012-December/023111.html
 Regular raster blocking]
 Here is [http://lists.osgeo.org/pipermail/postgis-
 devel/2012-December/023132.html confirmation of agreement] with minor
 editorial suggestions. Namely, the three rules are named as follows:
  1. Tile raster metadata
  2. Tile raster location
  3. Tile raster dimensions
 So, we have the final spec of the regular blocking. Further editing and
 polishing should happen in the SVN.
 Pierre, thanks for your support!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2122#comment:2>
