[postgis-devel] Error building extensions
Jose Carlos Martinez jomarlla at cgf.upv.es
Wed Feb 1 09:02:54 PST 2012
I cant build the extensions from r8999
make is running ok but after running make install i get (with
topology_extensions i got errors too):
Regards,
Jose
linux-8hd6:/mnt/tmp/postgis-2.0.0alpha3SVN/extensions/postgis # make install
expr: non-integer argument
if test "3SVNx" != "x"; then \
    v=; \
    while [[ $v -ge 1 ]]; do \
        cp -v sql_bits/postgis_upgrade_minor.sql
sql/postgis--2.0.0alphaSVN$v--2.0.0alpha3SVN.sql; \
        v=$(($v-1)); \
      done; \
else \
   if test 0SVN -gt 0; then \
    v=0; \
    while [[ $v -le  ]]; do \
sql/postgis--2.0.$v--2.0.0alpha3SVN.sql; \
        v=$(($v+1)); \
     done; \
   fi; \
  fi
/bin/sh: -c: line 9: unexpected argument `]]' to conditional binary operator
/bin/sh: -c: line 9: syntax error near `;'
/bin/sh: -c: line 9: `   while [[ $v -le  ]]; do \'
make: *** [sql_minor_upgrade] Error 1
