[postgis-devel] [PostGIS] #1525: [raster] Redefine and expand the keywords available to MapAlgebra expressions
PostGIS trac at osgeo.org
Wed Feb 1 14:43:08 PST 2012
expressions
 Reporter:  dustymugs    |       Owner:  pracine
     Type:  enhancement  |      Status:  new
 Priority:  critical     |   Milestone:  PostGIS 2.0.0
Component:  raster       |     Version:  2.0.x
 Keywords:               |
Comment(by strk):
 One idea could be prefixing with : That character is used by psql for
 expanding variables. Example:
 echo "select :n" | psql --set n="'hello'"
 So we would have:
 * :rast * :rast1 * :rast2
 Then I'd see those as roots for further detail, "rast" would identify the
 pixel taken in consideration, and you could then get more informations
 about it by adding a point and another label:
  * :rast.val
  * :rast.x
  * :rast.y
 Or the shorter and more underground:
  * :r.v :r.x :r.y
  * :r1.v :r1.x :r1.y
  * :r2.v :r2.x :r2.y
 Note that X and Y don't make things much slower (except in the keyword
 substitution phase, which can be optimized further). I also think all the
 other informations can be derived with a proper expression.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1525#comment:8>
