[postgis-devel] [PostGIS] #1501: [raster] regression failures
PostGIS trac at osgeo.org
Wed Feb 1 15:07:22 PST 2012
 Reporter:  gdt     |       Owner:  dzwarg
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.0.0
Component:  raster  |     Version:  trunk
 Keywords:          |
Comment(by gdt):
 I did; my test setup is to svn up, gmake clean, run autogen, run
 configure, build, and so on.
 What I meant is not that your atan2 fix caused the other problem, but that
 the other problem was now visible, whereas before the test never got that
 far, so I agree that the changes you made should not have affected the new
 problem, and I believe that they did not affect the new problem.
 Specifically, the first round of tests pass, and there is an error doing
 the upgrade.
 Why do you think "create type raster" is ok in a database that already has
 that type?  (See line 446 of postgis_update_20_minor.sql.)  Everything
 else is "create or replace", but "create or replace type" seems not legit.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1501#comment:9>
