[postgis-devel] [PostGIS] #1531: [raster] raster2pgsql loader aborts
PostGIS trac at osgeo.org
Thu Feb 2 09:08:41 PST 2012
  Reporter:  andreasft  |       Owner:  dustymugs
      Type:  defect     |      Status:  closed
  Priority:  medium     |   Milestone:  PostGIS 2.0.0
 Component:  raster     |     Version:  trunk
Resolution:  wontfix    |    Keywords:  raster2pgsql loader
Changes (by dustymugs):
  * status:  assigned => closed
  * resolution:  => wontfix
 I just tested the access_50k.zip and when run using the following command
 causes an abort:
 raster2pgsql -s 4326 -I acc_50k access > access.sql
 The following command does work due to the addition of the tiling flag:
 raster2pgsql -t 50x50 -s 4326 -I acc_50k access > access.sql
 From the looks of the raster, it has 43200x21600 pixels of datatype Int32.
 The loader attempts to allocate ~3732480000 bytes for the band and fails.
 The loader uses PostGIS raster's C API for handling the conversion from
 GDAL to raster hex.  I could replace the use of the API with a stream
 processor but I don't know if it is worth the effort.  Everything in
 PostGIS raster is performed in memory with no disk access (for temp files)
 but it may need to be considered if users are trying to load '''large'''
 rasters without tiling.
 It is strongly encouraged to tile your rasters as it does increase the
 performance of any queries run against the rasters.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1531#comment:3>
