[postgis-devel] [PostGIS] #1529: postgis alpha3 extension fails to install -- documentation st_pixelaspolygon
PostGIS trac at osgeo.org
Thu Feb 2 11:09:49 PST 2012
st_pixelaspolygon
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Pierre,
 I seriously doubt it.  alpha3 is r9003 (after Bborie's change).  I
 discovered it when testing the package
 http://www.postgis.org/download/windows/experimental.php
 So I had to hand patch it by removing the ST_Aspixelaspolygon comment from
 the extension.
 The extension picks up documentation / function inconsistencies because
 both get installed together as a single transaction whereas the regular
 installs the comments get installed as a separate file.
 It still holds true that before we make a release we should test this.
 Right now extensions aren't tested by our regress system and its a little
 too late to discover them once we've declared an alpha.  It was the same
 issue with alpha1.
 I suppose we could have our regress install the comments as well to catch
 these consistencies.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1529#comment:3>
