[postgis-devel] case statement to cath nulls on joined tables
Chris Hodgson chodgson at refractions.net
Thu Feb 2 18:35:34 PST 2012
This isn't really the right place for this question (perhaps the
postgresql users list?) but you'll find the syntax for the "case"
conditional here:
http://www.postgresql.org/docs/9.1/static/functions-conditional.html
The "coalesce" function (also described on that page) also does what you
want with less words.
Cheers,
Chris
On 12-02-02 06:25 PM, John Morgan wrote:
> Hello,
> I am doing a left outer join between a polygon table and a data
> table.Everything returns fine from this join as expected.However,
> there are cases where there isn’t data for a given polygon and this
> return as the expected null in the result set.I would like to utilize
> something like a case statement to catch the nulls and return a “more
> friendly” message.I have tried unsuccessfully to use the following logic:
> /Select case value_of_interest null then ‘more friendly message’ else
> value_of_interest end/
> /From poly_table left outer join data_table one poly_table.common_id =
> data_table.common_id/
> If someone could let me know where I am going wrong it would be
> greatly appreciated.
> Cheers,
> Derek
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120202/8cfa7eb2/attachment.html>
