[postgis-devel] [PostGIS] #1536: [raster] There should be an option for certain variants of ST_Intersection(raster, raster)
PostGIS trac at osgeo.org
Fri Feb 3 11:10:23 PST 2012
 Reporter:  pracine  |       Owner:  pracine
     Type:  defect   |      Status:  new
 Priority:  low      |   Milestone:  PostGIS 2.0.0
Component:  raster   |     Version:  trunk
 Keywords:           |
 All the variants of ST_Intersection accepting a extenttype argument should
 also allow to define a nodata value in case the input raster do not have
 one defined.
 Otherwise it leads to strange results like this:
 SELECT ST_AsBinary((gv).geom) geom,  (gv).val
 FROM (SELECT ST_PixelAsPolygons(
            ST_Intersection(ST_AddBand(ST_MakeEmptyRaster(48, 63, 0, 0,
 0.001, -0.001, 0, 0, 4269), '32BF'::text, 0, NULL),
                            ST_AddBand(ST_MakeEmptyRaster(48, 63, 0.1, 0.1,
 0.001, -0.001, 0, 0, 4269), '32BF'::text, 0, NULL)::geometry,
                            'SECOND')) gv) foo;
 in which:
 -the first raster do not have a nodata value defined,
 -the second parameter is just a dummy geometry to 'cut' the first raster,
 -we want the result to cover the extent of the geometry ('SECOND')
 so that we should get a lower left rectangle filled with zeros (0) and the
 rest of the extent filled with nodata.
 Instead we get just nodata :-(
 If ST_Intersection(raster, geometry, extenttype) would allow me to pass a
 nodata value, then I could make sure a correct nodata value is chosen and
 hence not annihilating my data.
 On the same track, why do the variants of ST_Intersection() taking a
 geometry allow me to define the resulting extent but not the variant
 taking two rasters? Actually why does the one taking a geometry allows me
 to define the resulting extent at all? This is an intersection operation,
 the result should always cover just the intersection. If I want something
 more sophisticated I should use ST_MapAlgebra(raster, raster).
 I'm working on a ST_Tile() plpgsql prototype using ST_Clip() and
 ST_Intersection(raster, geometry)...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1536>
