[postgis-devel] Removing: postgis_transform_geometry
Sandro Santilli strk at keybit.net
Fri Feb 3 23:41:54 PST 2012
On Fri, Feb 03, 2012 at 01:12:54PM -0800, Paul Ramsey wrote:
> While doing some renovation on transform, I found this old function.
> CREATE OR REPLACE FUNCTION postgis_transform_geometry(geometry,text,text,int)
> It appears disused and unloved, probably was an old testing function
> Dave used to do transformations prior to the hooking in of the
> spatial_ref_sys table. May I kill it?
I've just used it extensively on a project where proj4 itself
was falling short. It was extremely useful to implment chained
transforms, working around the lack of this feature of proj:
http://trac.osgeo.org/proj/ticket/136
So I'd be -1 on this. Would make PostGIS poorer.
--strk;
  ,------o-.
  |   __/  |    Thank you for PostGIS-2.0 Topology !
  |  / 2.0 |    http://www.pledgebank.com/postgistopology
  `-o------'
