[postgis-devel] [PostGIS] #1538: Geography should support SRIDs other than 4326
PostGIS trac at osgeo.org
Sat Feb 4 08:15:32 PST 2012
  Reporter:  pramsey      |       Owner:  pramsey
      Type:  enhancement  |      Status:  reopened
  Priority:  high         |   Milestone:  PostGIS 2.0.0
 Component:  postgis      |     Version:  trunk
Resolution:               |    Keywords:
Comment(by rouault):
 Unfortunately not. I do the same observation as you... I don't see
 anything in proj public API that could help. Perhaps FrankW would have one
 I have however an alternative suggestion, but not with proj. You could use
 GDAL OSR to retrieve those the a and f parameters. But GDAL isn't a
 required dependency of lwgeom I'm afraid...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1538#comment:4>
