[postgis-devel] [PostGIS] #126: Don't include private PROJ.4 header projects.h
trac at osgeo.org
Mon Feb 6 01:42:28 PST 2012
Reporter: mloskot | Type: task
Status: closed | Priority: medium
Milestone: PostGIS 1.4.0 | Component: postgis
Version: 1.4 | Resolution: fixed
Keywords: |
Old description:
> In current SVN trunk, PostGIS file lwgeom_transform.c includes private
> header of PROJ.4 - projects.h.
> This header is...private and should not be included form PROJ.4 client
> code.
> Instead, proj_api.h should be used. However, replacing these headers
> requires number of changes in lwgeom_transform.c. For instance, use API
> call(s) instead of accessing internal structures:
> current code:
> if( !srcdefn->is_latlong )
> new code:
> if( !pj_is_latlong( srcdefn ) )
> Including private header projects.h makes it impossible to compile using
> Microsoft Visual C++ compiler, becasue of well-known conflicts with
> definitions from windows.h. Here is confirmation of existence of that
> issue: [http://lists.osgeo.org/pipermail/gdal-dev/2005-May/005669.html
> http://lists.osgeo.org/pipermail/gdal-dev/2005-May/005669.html]
> I've just (re)hit this problem and it stops me from moving forward with
> building PostGIS using Visual C++.
New description:
code.
current code:
new code:
Comment(by strk):
This ticket lacks a reference to a revision id, ouch...
I think it was r3827 (thanks GIT for making the research so easy :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/126#comment:4>
