[postgis-devel] [PostGIS] #1542: tickets.sql tests fail
PostGIS trac at osgeo.org
Mon Feb 6 12:51:52 PST 2012
  Reporter:  strk     |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  invalid  |    Keywords:
Changes (by strk):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 annoying enough it turns out that "4.7.1 released 23 September 2009" is
 indeed PROJ trunk, advertising itself as such ...
 Dropping the new lib and the new header fixes the regression.
 Can't build with _only_ proj4 trunk due to the other bug you can now be
 thinking about a solution for :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1542#comment:10>
