[postgis-devel] [PostGIS] #1548: Documentation URLs, visible whitespace, and minor touchups
PostGIS trac at osgeo.org
Tue Feb 7 04:13:59 PST 2012
 Reporter:  mwtoews        |       Owner:  robe
     Type:  patch          |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.0
Component:  documentation  |     Version:  trunk
 Keywords:                 |
 See attached patch, ready to go for trunk.
 A summary of changes:
  * In general, updated URLs where needed.
  * Added some logical spaces, e.g.: "word,word" -> "word, word"; typically
 in "See Also" lists.
  * For links to the PostgreSQL Documentation, directing to the
 "current/static" version (the one without comments).
 Specifics:
  * {{{performance_tips.xml}}} - updated "checkpoint_segments" section.
 Removed "checkpoint_segment_size", since I can't even tell what version
 that was used. Also, I'm not sure what other "many configurations with
 names starting with checkpoint and WAL" would need to be mentioned here.
  * {{{installation.xml}}}
   * the {{{--prefix}}} parameter discussion is best covered in #635, not
 #160
   * #186 is dead, don't mention it
  * {{{reference_editor.xml}}} -  Deleted two obsolete references to
 {{{url="/support/wiki/index.php?plpgsqlfunctions"}}}
  * {{{reference_output.xml}}} - {{{ST_AsX3D}}} - there are a few
 references to "http://web3d.org/x3d/specifications/ISO-IEC-19776-1.2
 -X3DEncodings-XML/Part01/EncodingOfNodes.html", which doesn't link as it
 appears that V1.2 is not available -- only V3.0 and up. I didn't modify
 this, as I'm not sure if a later version is a suitable reference. If so,
 make it
 http://www.web3d.org/files/specifications/19776-1/V3.2/Part01/EncodingOfNodes.html
 Revise as needed.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1548>
