[postgis-devel] [PostGIS] #1536: [raster] There should be an option for setting the nodata value in certain variants of ST_Intersection(raster, raster) (was: [raster] There should be an option for certain variants of ST_Intersection(raster, raster))
PostGIS trac at osgeo.org
Tue Feb 7 06:58:48 PST 2012
 Reporter:  pracine  |       Owner:  pracine
     Type:  defect   |      Status:  new
 Priority:  low      |   Milestone:  PostGIS 2.0.0
Component:  raster   |     Version:  trunk
 Keywords:           |
Comment(by pracine):
 Also: At first I was thinking that those nodata value parameters should be
 used only when the requested band do not have a nodata value defined but I
 think this will become confusing.
 I think in the absence of such an argument, if the raster do not have a
 nodata value defined the ST_MinPossibleValue() should be used.
 If the argument is provided and the provided raster DO have a nodata value
 defined then the provided value should replace the nodata value of the
 raster (actually it does not replace it as we have to produce a new raster
 anyway).
 You can achieve this by passing the provided nodata value as the alternate
 expressions. Here is an example I use in ST_Tile():
 ST_SetBandNodataValue(ST_MapAlgebraExpr(rast, 1, geomrast, 1, 'RAST1',
 newpixtype, 'SECOND', newnodata::text, newnodata::text, newnodata),
 newnodata);
 As I said previously it is the responsability of the caller of
 ST_MapAlgebraExpr() to determine and set the new nodata value and the new
 pixel type.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1536#comment:18>
