[postgis-devel] [PostGIS] #1536: [raster] There should be an option for setting the nodata value in certain variants of ST_Intersection(raster, raster)
PostGIS trac at osgeo.org
Tue Feb 7 10:29:17 PST 2012
 Reporter:  pracine  |       Owner:  pracine
     Type:  defect   |      Status:  new
 Priority:  low      |   Milestone:  PostGIS 2.0.0
Component:  raster   |     Version:  trunk
 Keywords:           |
Comment(by pracine):
 Replying to [comment:19 dustymugs]:
 > So, only one NODATA parameter for ST_Intersection(raster, raster)?
 No. Two. Actually it depends on what band are requested. If 'BOTH' band
 are requested and no raster has a nodata value then we need two nodata
 values. I think the parameter should be an array so it can hold on or two
 values.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1536#comment:20>
