[postgis-devel] [PostGIS] #1353: [raster] ST_SetRotation incorrect
David Zwarg dzwarg+postgis at azavea.com
Wed Feb 8 14:29:25 PST 2012
Hello Bryce,
I dug through your git repository and nabbed out the st_geotransform
methods, put them in core and rt_pg. I replaced the rt_rotation test and
expected output with the values that you provided. I'm not sure if this
also resolves the preservation of the angle between the basis vectors --
does that feature rely on something else, or is it all included in the
geotransform code that you had in your repo?
Thanks,
David
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120208/50c8dde8/attachment.html>
