[postgis-devel] [PostGIS] #1505: Deal with database dumps containing geometries with SRID > MAX_SRID
PostGIS trac at osgeo.org
Wed Feb 8 15:55:20 PST 2012
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by pramsey):
 OK, here's the plan...
 If the SRID is > MAX_SRID we will take its 16-bit CRC. We'll then add that
 to the lower bound of a reserved space we can create to store out of range
 SRIDs. The advantage of the CRC is that it's deterministic, so we can
 apply the same trick if people insert a spatial_ref_sys record that is out
 of range: re-write the srid value and then insert it. That way a dump that
 includes geometries and spatial_ref_sys entries that are out of range will
 get re-written to use alternate SRIDs that are in range but still link up
 the geometry to the spatial_ref_sys srid value.
 This is the best I can do. We can add in notices to try and get people to
 see the problem and be aware for the future. We might alternative re-write
 the auth_srid and auth_name when translating an out of bounds
 spatial_ref_sys entry, but that would be a nicety.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1505#comment:1>
