[postgis-devel] distclean
Greg Troxel
gdt at ir.bbn.com
Wed Feb 8 19:09:31 PST 2012
I find that "gmake distclean" didn't clean as much as it should; it
seems Makefile and quite a few others are still present:
I configure
I config.guess
I config.sub
I ltmain.sh
I svnrevision.h
I GNUmakefile
I libtool
I aclocal.m4
I postgis/sqldefines.h
I postgis/Makefile
I postgis/postgis_upgrade_20_minor.sql.in
I extensions/postgis_topology/postgis_topology.control
I extensions/postgis_topology/Makefile
I extensions/postgis/postgis.control
I extensions/postgis/Makefile
I raster/test/core/Makefile
I raster/test/regress/Makefile
I raster/scripts/python/Makefile
I doc/topology_comments.sql
I doc/Makefile.comments
I doc/Makefile
I doc/tiger_geocoder_comments.sql
I doc/postgis_comments.sql
I doc/raster_comments.sql
I doc/html/image_src/Makefile
I libpgcommon/Makefile
I libpgcommon/cunit/Makefile
I topology/topology_drop_after.sql
I topology/topology_drop_before.sql
I topology/topology_upgrade.sql
I topology/Makefile
I topology/test/topo_predicates.sql
I topology/test/load_topology-4326.sql
I topology/test/load_topology.sql
I macros/libtool.m4
I macros/lt~obsolete.m4
I macros/ltsugar.m4
I macros/ltversion.m4
I macros/ltoptions.m4
I loader/Makefile
I loader/cunit/Makefile
I regress/Makefile
The following seems to help slightly:
Index: extensions/Makefile
--- extensions/Makefile (revision 9130)
+++ extensions/Makefile (working copy)
@@ -6,6 +6,10 @@
$(MAKE) -C postgis clean
$(MAKE) -C postgis_topology clean
+distclean:
+ $(MAKE) -C postgis distclean
+ $(MAKE) -C postgis_topology distclean
install:
$(MAKE) -C postgis install
$(MAKE) -C postgis_topology install
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120208/a25163de/attachment.pgp>
