[postgis-devel] [PostGIS] #1563: Can't upgrade from alpha3 to alpha4 with extension
PostGIS trac at osgeo.org
Thu Feb 9 02:52:10 PST 2012
 Reporter:  robe                   |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 Took care of the first issue at r9132.
 But now get another obstacle of CAN'T drop raster_columns view because
 postgis extension depends on it.
 GUYS you don't need to drop a view if you are adding a column at the end
 -- CREATE OR REPLACE VIEW can handle that.  It just can't handle data type
 changes.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1563#comment:1>
