[postgis-devel] [PostGIS] #547: ST_contains memory problem when used between polygon and mixed geometry
PostGIS trac at osgeo.org
Thu Feb 9 05:16:07 PST 2012
  Reporter:  twain    |       Owner:  strk
      Type:  defect   |      Status:  reopened
  Priority:  blocker  |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  1.5.X
Resolution:           |    Keywords:  ST_contains memory
Comment(by strk):
 Ok, I could reproduce by running ST_Intersects(A, A) OR ST_Intersects(A,
 P).
 Interesting enough the leak remains in the A-A case, doesn't matter if A-P
 is encountered, so the problem is fully with the prepared geometry cache,
 not the RTREE one. Which is the confusing function, btw. This is with
 ST_Intersects though (as the reporter for r8877 regression uses), not
 ST_Contains (which does _not_ seem to leak for me).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/547#comment:16>
