[postgis-devel] Spatial relationships not defined should return null
Jose Carlos Martinez Llario jomarlla at cgf.upv.es
Thu Feb 9 14:39:12 PST 2012
Hi list,
According to the standards the spatial predicates which are not defined
as st_touches (point , point) or st_overlaps (line, polygon) must return
null.
PostGIS returns false in those cases (trunk and previous versions too),
so it is against SQL/MM.
Should I open a ticket or this is the wanted behavior?
Regards,
Jose
