[postgis-devel] [PostGIS] #1505: Deal with database dumps containing geometries with SRID > MAX_SRID
PostGIS trac at osgeo.org
Fri Feb 10 08:03:50 PST 2012
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 To be clearer: if the dump has a check like this:
     "enforce_srid_geom2" CHECK (st_srid(geom2) = 999002)
 The core can't do anything about it, it'll always fail, so we need to fix
 at the restore end.
 Converting to typmod could do, but anyway if we _are_ the core we can't
 refuse to use 999002 because otherwise our system of reserved srids
 handling would also fail.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1505#comment:16>
