[postgis-devel] [PostGIS] #1505: Deal with database dumps containing geometries with SRID > MAX_SRID
PostGIS trac at osgeo.org
Fri Feb 10 08:22:20 PST 2012
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 So, early testing immediately hit the known limit:
   WARNING: SRID value 20123123 converted to 999123
   WARNING: SRID value 1123123123 converted to 999123
 ERROR:  duplicate key value violates unique constraint
 "spatial_ref_sys_pkey"
 That's converting using modulo over the reserved space composed by 1000
 slots.
 With same algorithm used by postgis_restore.pl and core.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1505#comment:20>
