[postgis-devel] Problem executing the regression tests on Windows 7
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Fri Feb 10 09:09:39 PST 2012
It did it! Committed. Thanks.
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
> Sent: Friday, February 10, 2012 11:40 AM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Problem executing the regression tests on Windows
> 7
> Looks like we need to leave a .bak file in place if we want to use that function...
> http://thiagumohan.blogspot.com/2009/11/perl-error-cant-do-inplace-edit-
> without.html
> P.
> On Fri, Feb 10, 2012 at 8:35 AM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> wrote:
> > When trying to execute the regression  tests on Windows 7, I get:
> > make[4]: Entering directory `/c/projects/postgis/postgis'
> > /bin/mkdir -p 'c:/projects/postgis/regress/00-regress-install/lib'
> install/share/contrib/postgis'
> > /bin/sh
> > c:/projects/pg/pg90/lib/POSTGR~1/pgxs/src/MAKEFI~1/../../config/install-sh -
> c -m 755  postgis-2.0.dll 'c:/projects/postgis/regress/0 0-regress-
> install/lib/postgis-2.0.dll'
> > /bin/sh
> > l-sh -c -m 644 ./../spatial_ref_sys.sql postgis.sql uninstall_
> > postgis.sql postgis_upgrade_20_minor.sql legacy.sql
> > uninstall_legacy.sql legacy_compatibility_layer.sql
> > ess-install/share/contrib/postgis/'
> > make[4]: Leaving directory `/c/projects/postgis/postgis'
> > /bin/perl -pi -e
> > 's,\$libdir,c:/projects/postgis/regress/00-regress-install/lib,g'
> > c:/projects/postgis/regress/00-regress-install/share/contrib/postgis/*
> > .sql Can't do inplace edit on
> install/share/contrib/postgis/legacy.sql: Permission denied.
> > Can't do inplace edit on c:/projects/postgis/regress/00-regress-
> install/share/contrib/postgis/legacy_compatibility_layer.sql: Permission denied.
> install/share/contrib/postgis/postgis.sql: Permission denied.
> install/share/contrib/postgis/postgis_upgrade_20_minor.sql: Permission denied.
> install/share/contrib/postgis/rtpostgis.sql: Permission denied.
> install/share/contrib/postgis/rtpostgis_drop.sql: Permission denied.
> install/share/contrib/postgis/rtpostgis_legacy.sql: Permission denied.
> install/share/contrib/postgis/rtpostgis_upgrade_20_minor.sql: Permission
> denied.
> install/share/contrib/postgis/rtpostgis_upgrade_cleanup.sql: Permission denied.
> install/share/contrib/postgis/spatial_ref_sys.sql: Permission denied.
> install/share/contrib/postgis/topology.sql: Permission denied.
> install/share/contrib/postgis/topology_upgrade_20_minor.sql: Permission
> denied.
> install/share/contrib/postgis/uninstall_legacy.sql: Permission denied.
> install/share/contrib/postgis/uninstall_postgis.sql: Permission denied.
> install/share/contrib/postgis/uninstall_rtpostgis.sql: Permission denied.
> install/share/contrib/postgis/uninstall_topology.sql: Permission denied.
> > The install command works fine but when perl tries to edit the files it delete
> them and then display 'Can't do inplace...'.
> > Any idea?
> > Thanks,
> > Pierre
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
