[postgis-devel] [PostGIS] #1494: Ability to load census tract/block data when loading tiger_geocoder with shapefiles
PostGIS trac at osgeo.org
Tue Feb 14 11:07:54 PST 2012
shapefiles
  Reporter:  kiwi            |       Owner:  robe
      Type:  enhancement     |      Status:  closed
  Priority:  medium          |   Milestone:  PostGIS 2.0.0
 Component:  tiger geocoder  |     Version:  trunk
Resolution:  fixed           |    Keywords:
Changes (by robe):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 I'm going to consider this done at r9191, r9190.
 I changed the name of the function to:
 SELECT loader_generate_census_script(ARRAY['TX'], 'sh');
 details of new census tract loader and get_tract functions in docs
 http://www.postgis.org/documentation/manual-
 svn/Loader_Generate_Census_Script.html
 http://www.postgis.org/documentation/manual-svn/Get_Tract.html
 You should get these new features by just running the update_geocoder.sh
 script.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1494#comment:3>
