[postgis-devel] [PostGIS] #1570: in_gml, in_kml crashing and many regrss tests failing on mingw
PostGIS trac at osgeo.org
Wed Feb 15 00:40:51 PST 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Okay I recompiled my alpha2 using the same current script I am using to
 compile alpha4 and alpha2 resulting dll is fine in that the above test
 returns something.
 So unless I am loosing my mind (which I can't discount), something changed
 between alpha2 and alpha3 to cause this issue.
 Pierre -- you are running the same mingw version I am.  Can you check and
 see if the above passes.  I'm running on a windows 7 64-bit so that might
 make a difference.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1570#comment:3>
