[postgis-devel] [PostGIS] #1570: in_gml, in_kml crashing and many regrss tests failing on mingw
PostGIS trac at osgeo.org
Wed Feb 15 12:43:22 PST 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Interesting.  All my cunits pass. Are you on windows 7 32-bit or 7 64-bit
 or some other windows?.
  in_gml / in_kml I guess I'll have to hunt what changed between alpha2 and
 alpha3.  Originally I thought it was something I was doing during the
 compile process (to revert back to issues I had in 1.5), but fact
 recompiling the alpha2 gives me a good buld and you have the same issue
 would seem to dispell that notion.
 As far as regress_* and typmod tickets, I don't think those are true
 failures but result of the tests crashing on in_gml/in_kml and tickets and
 the postgres process trying to stand back up from a knockout punch.
 Thanks Pierre :)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1570#comment:5>
