[postgis-devel] [PostGIS] #1571: ST_ChangeEdgeGeom lets you break topology
PostGIS trac at osgeo.org
Fri Feb 17 01:55:00 PST 2012
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 It turns out it's not that easy.
 This image shows a case in which it is hard to find the "motion range
 polygon" (the polygon which should represent the movement taken from the
 original edge to become the new edge).
 [[Image(motion.png)]]
 There we go from the RED edge to the YELLOW edge.
 Sounds like a motion planning problem in that there are multiple possible
 paths to get from one point to the other, go figure if there's at least
 _one_ path not resulting in collision with node 4...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1571#comment:7>
