[postgis-devel] v2.0 Alpha testing
pcreso at pcreso.com pcreso at pcreso.com
Sat Feb 18 19:42:04 PST 2012
Very limited testing, environment entirely standard OpenSuse v12.1 64bit, KDE.
GIS apps via packages from OpenSuse Geo repository (the main reason I use OpenSuse):
./configure --with-topology
<sort out dependencies until success>
make
make check
<output>
 PostgreSQL 9.1.1 on x86_64-suse-linux-gnu, compiled by gcc (SUSE Linux) 4.6.2, 64-bit
 Postgis 2.0.0alpha6SVN - r - 2012-02-19 03:27:11
   GEOS: 3.3.2-CAPI-1.7.2
   PROJ: Rel. 4.7.1, 23 September 2009
Run tests: 83
Failed: 0
+1 so far...
now for make install & further checks as time permits
Thanks guys!!!!
  Brent Wood
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120218/25ed5ddc/attachment.html>
