[postgis-devel] [PostGIS] #1586: [raster] st_dumpaspolygons makes not valid polygons
PostGIS trac at osgeo.org
Mon Feb 20 11:37:01 PST 2012
 Reporter:  jomarlla  |       Owner:  pracine
     Type:  defect    |      Status:  new
 Priority:  high      |   Milestone:  PostGIS 2.0.0
Component:  raster    |     Version:  trunk
 Keywords:            |
Comment(by dustymugs):
 After doing some thinking about GDALPolygonize() and GDALFPolygonize()
 (both used by ST_DumpAsPolygons), it is possible/probably for invalid
 polygons to be generated.  From the GDAL API docs for GDALPolygonize:
 This function creates vector polygons for all connected regions of pixels
 in the raster sharing a common pixel value
 Two pixels with the same value with one common corner may cause a bow-
 tie...
 I don't see any way to make GDAL generate valid polygons but we could add
 a validation routine to the appropriate C code in rt_api.c.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1586#comment:6>
