[postgis-devel] [PostGIS] #1590: Still regression failures with trunk on mingw
PostGIS trac at osgeo.org
Mon Feb 20 12:24:00 PST 2012
 Reporter:  robe            |       Owner:  pramsey
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis         |     Version:  trunk
 Keywords:  mingw, windows  |
 As of r9241, still getting a lot of regression failures.  I suspect the
 later failures are because mingw is crashing on tickets test.
 Here is what I have.
 all pass up to this point and start failing on tickets.
  tickets .. failed (diff expected obtained:
 /tmp/pgis_reg_3680/test_65_diff)
  typmod .. failed (diff expected obtained:
 /tmp/pgis_reg_3680/test_66_diff)
  remove_repeated_points .. failed (diff expected obtained:
 /tmp/pgis_reg_3680/te          st_67_diff)
  split .. failed (diff expected obtained: /tmp/pgis_reg_3680/test_68_diff)
  relate .. failed (diff expected obtained:
 /tmp/pgis_reg_3680/test_69_diff)
  bestsrid .. failed (diff expected obtained:
 /tmp/pgis_reg_3680/test_70_diff)
  concave_hull .. failed (diff expected obtained:
 /tmp/pgis_reg_3680/test_71_diff          )
  hausdorff .. failed (diff expected obtained:
 /tmp/pgis_reg_3680/test_72_diff)
  regress_buffer_params .. failed (diff expected obtained:
 /tmp/pgis_reg_3680/tes          t_73_diff)
  offsetcurve .. failed (diff expected obtained:
 /tmp/pgis_reg_3680/test_74_diff)
  relatematch .. failed (diff expected obtained:
 /tmp/pgis_reg_3680/test_75_diff)
  isvaliddetail .. ok
  sharedpaths .. ok
  snap .. ok
  node .. ok
  unaryunion .. ok
  clean .. ok
  relate_bnr .. ok
  uninstall .. ok (3855)
 Run tests: 83
 Failed: 11
 make[1]: *** [check] Error 11
 make[1]: Leaving directory `/c/projects/PostGIS/trunk/regress'
 make: *** [check] Error 1
 I'll take tickets out to confirm rest pass without it and try to see what
 test in tickets is causing the crash.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1590>
