[postgis-devel] #1586: st_dumpaspolygons makes not valid polygons
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Mon Feb 20 12:48:10 PST 2012
> >  I don't see any way to make GDAL generate valid polygons but we could
> > add  a validation routine to the appropriate C code in rt_api.c.
> Does GDAL return a _single_ polygon always ? Because from the description it
> seems it returns polygons (plural) and the above would be a valid multipolygon...
Good point. Please you add this to the ticket...
