[postgis-devel] [PostGIS] #964: Support for PostgreSQL 9.1+ new Extensions model
PostGIS trac at osgeo.org
Tue Feb 21 01:45:59 PST 2012
 Reporter:  robe         |       Owner:  robe
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by strk):
 Alright, with r9243 we have an --extensions switch to run_test.
 You can try that manually running run_test or specifying it as part of
 RUNTESTFLAGS, ie:
 $ make check RUNTESTFLAGS='--extensions -v'
 You'll get failures from tickets.sql where having both raster _and_ core
 in the same spatial db introduces ambiguities. Is this an occasion to
 disambiguate at the rtpostgis.sql level like we did in other cases or
 should we update the testcase instead ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/964#comment:12>
