[postgis-devel] [PostGIS] #1596: UpdateGeometryColumn allows	invalid SRIDs
    trac at osgeo.org
    Wed Feb 22 03:28:50 PST 2012
 Reporter:  mwtoews  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 As hinted from #1594, you can !AddGeometryColumn with an unknown SRID,
 then use UpdateGeometrySRID to sneak in an invalid SRID -- one that is not
 in spatial_ref_sys:
 -- All good
 create table a (gid serial primary key);
 select AddGeometryColumn('a', 'geom', -1, 'POINT', 2);
 -- Shouldn't happen
 select UpdateGeometrySRID('a', 'geom', 123456);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1596>
