[postgis-devel] [PostGIS] #1606: upgrade script failure: error can not change name of input parameter "new_srid"
PostGIS trac at osgeo.org
Wed Feb 22 18:35:44 PST 2012
"new_srid"
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by mwtoews):
 This error stemmed from #1596. The last parameter in UpdateGeometrySRID,
 `new_srid`, was renamed to `new_srid_in`. The rational was to somewhat
 mimic !AddGeometryColumn. This can be modified back, if required. (Another
 internal variable name like `new_srid_mod` would need to be used within
 UpdateGeometrySRID, since the IN parameters are CONST and this var may
 change to `unknown_srid`).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1606#comment:2>
