[postgis-devel] [PostGIS] #1605: Set SVN properties for EOL or MIME type
PostGIS trac at osgeo.org
Thu Feb 23 03:18:55 PST 2012
 Reporter:  mwtoews     |       Owner:  chodgson
     Type:  patch       |      Status:  new
 Priority:  low         |   Milestone:  PostGIS 2.0.0
Component:  management  |     Version:  trunk
 Keywords:              |
Comment(by mcayland):
 Another thing to point out here: I remember when I was doing the Windows
 builds that the regression test output files need to unix-style (LF) in
 order to work correctly under MingW. Perhaps Regina can confirm that this
 is still the case, however I thought I should mention it if we are about
 to embark on a full-blown SVN property change mission.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1605#comment:5>
