[postgis-devel] [PostGIS] #1614: More normalizer tricks
PostGIS trac at osgeo.org
Fri Feb 24 12:00:33 PST 2012
 Reporter:  mikepease       |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  tiger geocoder  |     Version:  1.5.X
 Keywords:                  |
 --Specifying St. Paul but not MN misinterprets state
 select * from normalize_address('933 Vandalia Ave, St Paul');
 --Output PALAU (PW)??
 --933  ""  "Vandalia"  ""  ""  ""  "St"  "PW"  ""  t
 select  * from normalize_address('933 Vandalia, St. Paul, 55304') ;
 --Still goes to Palau
 select  * from normalize_address('933 Vandalia, St. Paul, MN')
 --Works properly
 -Why is the syntax so sensitive here?
 --none of these work right
 select  * from normalize_address('901 Mainstreet, Fl 2, Hopkins MN 55343')
 select  * from normalize_address('901 Mainstreet Fl 2, Hopkins, MN 55343')
 select  * from normalize_address('901 Mainstreet Fl 2 Hopkins, MN 55343')
 select  * from normalize_address('901 Mainstreet, Fl 2 Hopkins, MN 55343')
 select  * from normalize_address('901 Mainstreet St, Fl 2 Hopkins, MN
 55343')
 --this one does
 select  * from normalize_address('901 Mainstreet St Fl 2, Hopkins, MN
 55343')
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1614>
