[postgis-devel] [PostGIS] #1617: [raster] several regress failures on raster (old mingw) (was: several regress failures on raster (old mingw))
PostGIS trac at osgeo.org
Sun Feb 26 10:37:13 PST 2012
 Reporter:  robe     |       Owner:  pracine
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  raster   |     Version:  trunk
 Keywords:  mingw    |
Comment(by dustymugs):
 Can either of you test out raster/test/core/testapi.c from 9303?  I've
 added another test of the GDAL PNG output.  I'm expecting that to cause a
 crash in Windows.  I hope that will make the crash easier to debug.
 I'm not seeing this issue in Linux 32 and 64-bit (GDAL trunk r24025) and
 OSX (GDAL release 1.9.0), which makes things even stranger.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1617#comment:6>
