[postgis-devel] PostGIS compile problem
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Tue Feb 28 13:52:03 PST 2012
$ ./autogen.sh
* Running /mingw/bin/libtoolize (2.2.10)
   OPTIONS = --force --copy --install
libtoolize: putting auxiliary files in `.'.
libtoolize: copying file `./config.guess'
libtoolize: copying file `./config.sub'
libtoolize: copying file `./install-sh'
libtoolize: copying file `./ltmain.sh'
libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `macros'.
libtoolize: copying file `macros/libtool.m4'
libtoolize: copying file `macros/ltoptions.m4'
libtoolize: copying file `macros/ltsugar.m4'
libtoolize: copying file `macros/ltversion.m4'
libtoolize: copying file `macros/lt~obsolete.m4'
libtoolize: Consider adding `-I macros' to ACLOCAL_AMFLAGS in Makefile.am.
* Running /mingw/bin/aclocal (1.11)
* Running /mingw/bin/autoconf (2.65)
Now you are ready to run './configure'
$ ./configure --with-xml2config=/c/projects/libxml/libxml2-2.7.8release/bin/xml2-config --with-pgconfig=/c/projects/pg/pg90/bin/pg_config -
-with-geosconfig=/c/projects/geos/rel-3.3.2/bin/geos-config --with-projdir=/c/projects/pg/pg90 --with-gdalconfig=/c/projects/gdal/rel-1.9.0
/bin/gdal-config
checking build system type... i686-pc-mingw32
checking host system type... i686-pc-mingw32
checking how to print strings... printf
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.exe
checking for suffix of executables... .exe
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... c:/mingw/mingw32/bin/ld.exe
checking if the linker (c:/mingw/mingw32/bin/ld.exe) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /mingw/bin/nm
checking the name lister (/mingw/bin/nm) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 8192
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for c:/mingw/mingw32/bin/ld.exe option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... file_magic ^x86 archive import|^x86 DLL
checking for ar... ar
checking for strip... strip
checking for ranlib... ranlib
checking for gawk... gawk
checking command to parse /mingw/bin/nm output from gcc object... ok
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... no
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -DDLL_EXPORT -DPIC
checking if gcc PIC flag -DDLL_EXPORT -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (c:/mingw/mingw32/bin/ld.exe) supports shared libraries... yes
checking whether -lc should be explicitly linked in... yes
checking dynamic linker characteristics... Win32 ld.exe
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking how to run the C++ preprocessor... g++ -E
checking for ld used by g++... c:/mingw/mingw32/bin/ld.exe
checking whether the g++ linker (c:/mingw/mingw32/bin/ld.exe) supports shared libraries... yes
checking for g++ option to produce PIC... -DDLL_EXPORT -DPIC
checking if g++ PIC flag -DDLL_EXPORT -DPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
checking if g++ supports -c -o file.o... (cached) yes
checking for ant... no
checking if g++ supports -Wall... yes
checking if g++ supports -Wmissing-prototypes... yes
checking if g++ supports -ffloat-store... yes
checking for flex... flex
checking lex output file root... lex.yy
checking lex library... -lfl
checking whether yytext is a pointer... yes
checking for bison... bison -y
checking ieeefp.h usability... no
checking ieeefp.h presence... no
checking for ieeefp.h... no
checking termios.h usability... no
checking termios.h presence... no
checking for termios.h... no
checking for vasprintf... no
checking for asprintf... no
checking for _LARGEFILE_SOURCE value needed for large files... unknown
checking for perl... /bin/perl
checking for convert... /c/Windows/system32/convert
checking for xsltproc... no
checking for xmllint... /c/projects/pg/pg90/bin/xmllint
checking for dblatex... no
checking CUnit/CUnit.h usability... yes
checking CUnit/CUnit.h presence... yes
checking for CUnit/CUnit.h... yes
checking for CU_initialize_registry in -lcunit... yes
checking iconv.h usability... yes
checking iconv.h presence... yes
checking for iconv.h... yes
checking for libiconv_open in -liconv... yes
checking for iconvctl... no
checking for libiconvctl... no
Using user-specified pg_config file: /c/projects/pg/pg90/bin/pg_config
checking PostgreSQL version... PostgreSQL 9.1.2
checking libpq-fe.h usability... yes
checking libpq-fe.h presence... yes
checking for libpq-fe.h... yes
checking for PQserverVersion in -lpq... yes
Using user-specified xml2-config file: /c/projects/libxml/libxml2-2.7.8release/bin/xml2-config
checking libxml/tree.h usability... yes
checking libxml/tree.h presence... yes
checking for libxml/tree.h... yes
checking libxml/parser.h usability... yes
checking libxml/parser.h presence... yes
checking for libxml/parser.h... yes
checking libxml/xpath.h usability... yes
checking libxml/xpath.h presence... yes
checking for libxml/xpath.h... yes
checking libxml/xpathInternals.h usability... yes
checking libxml/xpathInternals.h presence... yes
checking for libxml/xpathInternals.h... yes
checking for xmlInitParser in -lxml2... yes
Using user-specified geos-config file: /c/projects/geos/rel-3.3.2/bin/geos-config
checking GEOS version... 3.3.2
checking geos_c.h usability... yes
checking geos_c.h presence... yes
checking for geos_c.h... yes
checking for initGEOS in -lgeos_c... yes
checking whether make sets $(MAKE)... yes
checking for a BSD-compatible install... /bin/install -c
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking whether NLS is requested... yes
checking for msgfmt... no
checking for gmsgfmt... :
checking for xgettext... no
checking for msgmerge... no
checking for ld used by GCC... c:/mingw/mingw32/bin/ld.exe
checking for shared library run path origin... done
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for GNU gettext in libc... no
checking for iconv... yes
checking for working iconv... yes
checking for GNU gettext in libintl... no
checking whether to use NLS... no
Using user-specified proj directory: /c/projects/pg/pg90
checking proj_api.h usability... yes
checking proj_api.h presence... yes
checking for proj_api.h... yes
checking for pj_get_release in -lproj... yes
checking json/json.h usability... no
checking json/json.h presence... no
checking for json/json.h... no
checking for json_object_get in -ljson... no
TOPOLOGY: Topology support requested
checking for GDAL >= 1.6.0... found
checking for GDALFPolygonize in -lgdal... no
configure: creating ./config.status
config.status: creating GNUmakefile
config.status: creating extensions/Makefile
config.status: creating extensions/postgis/Makefile
config.status: creating extensions/postgis/postgis.control
config.status: creating extensions/postgis_topology/Makefile
config.status: creating extensions/postgis_topology/postgis_topology.control
config.status: creating liblwgeom/Makefile
config.status: creating liblwgeom/cunit/Makefile
config.status: creating liblwgeom/liblwgeom.h
config.status: creating libpgcommon/Makefile
config.status: creating libpgcommon/cunit/Makefile
config.status: creating postgis/Makefile
config.status: creating postgis/sqldefines.h
config.status: creating loader/Makefile
config.status: creating loader/cunit/Makefile
config.status: creating topology/Makefile
config.status: creating regress/Makefile
config.status: creating doc/Makefile
config.status: creating doc/Makefile.comments
config.status: creating doc/html/image_src/Makefile
config.status: creating utils/Makefile
config.status: creating java/jdbc/Makefile
config.status: creating raster/Makefile
config.status: creating raster/rt_core/Makefile
config.status: creating raster/rt_pg/Makefile
config.status: creating raster/loader/Makefile
config.status: creating raster/test/Makefile
config.status: creating raster/test/core/Makefile
config.status: creating raster/test/regress/Makefile
config.status: creating raster/scripts/Makefile
config.status: creating raster/scripts/python/Makefile
config.status: creating postgis_config.h
config.status: postgis_config.h is unchanged
config.status: creating raster/raster_config.h
config.status: raster/raster_config.h is unchanged
config.status: executing libtool commands
config.status: executing po-directories commands
  PostGIS is now configured for i686-pc-mingw32
 -------------- Compiler Info -------------
  C compiler:           gcc -g -O2
  C++ compiler:         g++ -g -O2
 -------------- Dependencies --------------
  GEOS config:          /c/projects/geos/rel-3.3.2/bin/geos-config
  GEOS version:         3.3.2
  GDAL config:          /c/projects/gdal/rel-1.9.0/bin/gdal-config
  GDAL version:         1.9.0
  PostgreSQL config:    /c/projects/pg/pg90/bin/pg_config
  PostgreSQL version:   PostgreSQL 9.1.2
  PROJ4 version:        46
  Libxml2 config:       /c/projects/libxml/libxml2-2.7.8release/bin/xml2-config
  Libxml2 version:      2.7.8
  JSON-C support:       no
  PostGIS debug level:  0
  Perl:                 /bin/perl
 --------------- Extensions ---------------
  PostGIS Raster:       enabled
  PostGIS Topology:     enabled
 -------- Documentation Generation --------
  xsltproc:
  xsl style sheets:
  dblatex:
  convert:              /c/Windows/system32/convert
  mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
> Sent: Tuesday, February 28, 2012 4:46 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] PostGIS compile problem
> Environment, tool-chain? ./autogen, ./configure?
> P
> On Tue, Feb 28, 2012 at 1:43 PM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> wrote:
> > Hi,
> > I just updated my geos to this one:
> > http://download.osgeo.org/geos/geos-3.3.2.tar.bz2
> > (the svn trunk does not compile) and still PostGIS complain with like this:
> > /bin/sh ../libtool --mode=compile gcc -g -O2  -DDLL_EXPORT -DPIC
> > -Wall -Wmissing-prototypes -I/c/projects/geos/rel-3.3.2/include
> > -I/c/proje cts/pg/pg90/include -c -o lwgeom_geos.lo lwgeom_geos.c
> > libtool: compile:  gcc -g -O2 -DDLL_EXPORT -DPIC -Wall
> > -I/c/projects/pg/pg90/inclu de -c lwgeom_geos.c  -DDLL_EXPORT -DPIC -o
> > .libs/lwgeom_geos.o
> > lwgeom_geos.c: In function `lwgeom_snap':
> > lwgeom_geos.c:937: error: `POSTGIS_GEOS_VERSION' undeclared (first use
> > in this function)
> > lwgeom_geos.c:937: error: (Each undeclared identifier is reported only
> > once
> > lwgeom_geos.c:937: error: for each function it appears in.)
> > lwgeom_geos.c: In function `lwgeom_sharedpaths':
> > lwgeom_geos.c:1001: error: `POSTGIS_GEOS_VERSION' undeclared (first
> > use in this function)
> > lwgeom_geos.c: In function `LWGEOM2GEOS':
> > lwgeom_geos.c:265: warning: unreachable code at beginning of switch
> > statement
> > make[1]: *** [lwgeom_geos.lo] Error 1
> > make[1]: Leaving directory `/c/projects/postgis/liblwgeom'
> > make: *** [all] Error 1
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
