[postgis-devel] PostGIS compile problem
Paul Ramsey pramsey at opengeo.org
Tue Feb 28 16:09:20 PST 2012
None. It's supposed to be generated from postgis_config.h.in at ./configure time
P.
On Tue, Feb 28, 2012 at 4:07 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca> wrote:
> Nothing is defined in my postgis_config.h
> Any idea why?
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>> bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
>> Sent: Tuesday, February 28, 2012 7:06 PM
>> To: PostGIS Development Discussion
>> Subject: Re: [postgis-devel] PostGIS compile problem
>> It should be defined in postgis_config.h
>> On Tue, Feb 28, 2012 at 4:04 PM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
>> wrote:
>> > Still can't compile. Where should be defined this POSTGIS_GEOS_VERSION?
>> Can't find it...
>> >> [mailto:postgis-devel- bounces at postgis.refractions.net] On Behalf Of
>> >> Pierre Racine
>> >> Sent: Tuesday, February 28, 2012 4:52 PM
>> >> $ ./autogen.sh
>> >> * Running /mingw/bin/libtoolize (2.2.10)
>> >>    OPTIONS = --force --copy --install
>> >> libtoolize: putting auxiliary files in `.'.
>> >> libtoolize: copying file `./config.guess'
>> >> libtoolize: copying file `./config.sub'
>> >> libtoolize: copying file `./install-sh'
>> >> libtoolize: copying file `./ltmain.sh'
>> >> libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `macros'.
>> >> libtoolize: copying file `macros/libtool.m4'
>> >> libtoolize: copying file `macros/ltoptions.m4'
>> >> libtoolize: copying file `macros/ltsugar.m4'
>> >> libtoolize: copying file `macros/ltversion.m4'
>> >> libtoolize: copying file `macros/lt~obsolete.m4'
>> >> libtoolize: Consider adding `-I macros' to ACLOCAL_AMFLAGS in Makefile.am.
>> >> * Running /mingw/bin/aclocal (1.11)
>> >> * Running /mingw/bin/autoconf (2.65)
>> >> Now you are ready to run './configure'
>> >> $ ./configure --with-xml2config=/c/projects/libxml/libxml2-
>> >> 2.7.8release/bin/xml2-config --with-
>> >> pgconfig=/c/projects/pg/pg90/bin/pg_config - -with-
>> >> geosconfig=/c/projects/geos/rel-3.3.2/bin/geos-config --with-
>> >> projdir=/c/projects/pg/pg90
>> >> --with-gdalconfig=/c/projects/gdal/rel-1.9.0
>> >> /bin/gdal-config
>> >> checking build system type... i686-pc-mingw32 checking host system type...
>> >> i686-pc-mingw32 checking how to print strings... printf checking for
>> >> gcc... gcc checking whether the C compiler works... yes checking for
>> >> C compiler default output file name... a.exe checking for suffix of
>> >> executables... .exe checking whether we are cross compiling... no
>> >> checking for suffix of object files... o checking whether we are
>> >> using the GNU C compiler... yes checking whether gcc accepts -g...
>> >> yes checking for gcc option to accept ISO C89... none needed checking
>> >> for a sed that does not truncate output... /bin/sed checking for grep
>> >> that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E
>> checking for fgrep... /bin/grep -F checking for ld used by gcc...
>> >> c:/mingw/mingw32/bin/ld.exe checking if the linker
>> >> (c:/mingw/mingw32/bin/ld.exe) is GNU ld... yes checking for BSD- or
>> >> MS- compatible name lister (nm)... /mingw/bin/nm checking the name
>> >> lister
>> >> (/mingw/bin/nm) interface... BSD nm checking whether ln -s works...
>> >> yes checking the maximum length of command line arguments... 8192
>> >> checking whether the shell understands some XSI constructs... yes
>> >> checking whether the shell understands "+="... yes checking for
>> >> c:/mingw/mingw32/bin/ld.exe option to reload object files... -r
>> >> checking for objdump... objdump checking how to recognize dependent
>> >> libraries... file_magic ^x86 archive import|^x86 DLL checking for
>> >> ar... ar checking for strip... strip checking for ranlib... ranlib
>> >> checking for gawk... gawk checking command to parse /mingw/bin/nm
>> >> output from gcc object... ok checking how to run the C
>> >> preprocessor... gcc -E checking for ANSI C header files... yes
>> >> checking for sys/types.h... yes checking for sys/stat.h... yes
>> >> checking for stdlib.h... yes checking for string.h... yes checking
>> >> for memory.h... yes checking for strings.h... yes checking for
>> >> inttypes.h... yes checking for stdint.h... yes checking for
>> >> unistd.h... yes checking for dlfcn.h... no checking for objdir...
>> >> .libs checking if gcc supports -fno-rtti -fno-exceptions... no
>> >> checking for gcc option to produce PIC... -DDLL_EXPORT -DPIC checking
>> >> if gcc PIC flag -DDLL_EXPORT -DPIC works... yes checking if gcc
>> >> static flag -static works... yes checking if gcc supports -c -o
>> >> file.o... yes checking if gcc supports -c -o file.o... (cached) yes
>> >> checking whether the gcc linker
>> >> (c:/mingw/mingw32/bin/ld.exe) supports shared libraries... yes
>> >> checking whether -lc should be explicitly linked in... yes checking
>> >> dynamic linker characteristics... Win32 ld.exe checking how to
>> >> hardcode library paths into programs... immediate checking whether
>> >> stripping libraries is possible... yes checking if libtool supports
>> >> shared libraries... yes checking whether to build shared libraries...
>> >> yes checking whether to build static libraries... yes checking for gcc...
>> (cached) gcc checking whether we are using the GNU C compiler...
>> >> (cached) yes checking whether gcc accepts -g... (cached) yes checking
>> >> for gcc option to accept ISO C89... (cached) none needed checking how
>> >> to run the C preprocessor... gcc -E checking for g++... g++ checking
>> >> whether we are using the GNU C++ compiler... yes checking whether g++
>> >> accepts -g... yes checking how to run the C++ preprocessor... g++ -E checking
>> for ld used by g++...
>> >> (c:/mingw/mingw32/bin/ld.exe) is GNU ld... yes checking whether the
>> >> g++ linker
>> >> checking for g++ option to produce PIC... -DDLL_EXPORT -DPIC checking
>> >> if g++ PIC flag - DDLL_EXPORT -DPIC works... yes checking if g++
>> >> static flag -static works... yes checking if g++ supports -c -o file.o... yes
>> >> (cached) yes checking whether the g++ linker
>> >> checking dynamic linker characteristics... Win32 ld.exe checking how
>> >> to hardcode library paths into programs... immediate checking for
>> >> ant... no checking if g++ supports -Wall... yes checking if g++ supports -
>> Wmissing-prototypes... yes checking if g++ supports -ffloat-store...
>> >> yes checking for flex... flex checking lex output file root... lex.yy
>> >> checking lex library... -lfl checking whether yytext is a pointer... yes checking
>> for bison...
>> >> bison -y checking ieeefp.h usability... no checking ieeefp.h
>> >> presence... no checking for ieeefp.h... no checking termios.h
>> >> usability... no checking termios.h presence... no checking for
>> >> termios.h... no checking for vasprintf... no checking for asprintf...
>> >> no checking for _LARGEFILE_SOURCE value needed for large files... unknown
>> checking for perl... /bin/perl checking for convert...
>> >> /c/Windows/system32/convert checking for xsltproc... no checking for
>> xmllint...
>> >> /c/projects/pg/pg90/bin/xmllint checking for dblatex... no checking
>> >> CUnit/CUnit.h usability... yes checking CUnit/CUnit.h presence... yes
>> >> checking for CUnit/CUnit.h... yes checking for CU_initialize_registry
>> >> in -lcunit... yes checking iconv.h usability... yes checking iconv.h
>> >> presence... yes checking for iconv.h... yes checking for libiconv_open in -
>> liconv... yes checking for iconvctl...
>> >> no checking for libiconvctl... no Using user-specified pg_config file:
>> >> /c/projects/pg/pg90/bin/pg_config checking PostgreSQL version...
>> >> PostgreSQL
>> >> 9.1.2 checking libpq-fe.h usability... yes checking libpq-fe.h
>> >> presence... yes checking for libpq-fe.h... yes checking for
>> >> PQserverVersion in -lpq... yes Using user-specified xml2-config file:
>> >> /c/projects/libxml/libxml2- 2.7.8release/bin/xml2-config checking
>> >> libxml/tree.h usability... yes checking libxml/tree.h presence... yes
>> >> checking for libxml/tree.h... yes checking libxml/parser.h
>> >> usability... yes checking libxml/parser.h presence... yes checking
>> >> for libxml/parser.h... yes checking libxml/xpath.h usability... yes
>> >> checking libxml/xpath.h presence... yes checking for
>> >> libxml/xpath.h... yes checking libxml/xpathInternals.h usability...
>> >> yes checking libxml/xpathInternals.h presence... yes checking for
>> >> libxml/xpathInternals.h... yes checking for xmlInitParser in -lxml2... yes Using
>> user-specified geos-config file:
>> >> checking GEOS version... 3.3.2
>> >> checking geos_c.h usability... yes
>> >> checking geos_c.h presence... yes
>> >> checking for geos_c.h... yes
>> >> checking for initGEOS in -lgeos_c... yes checking whether make sets
>> $(MAKE)...
>> >> yes checking for a BSD-compatible install... /bin/install -c checking
>> >> for a thread- safe mkdir -p... /bin/mkdir -p checking whether NLS is
>> >> requested... yes checking for msgfmt... no checking for gmsgfmt... :
>> >> checking for xgettext... no
>> >> checking for msgmerge... no
>> >> checking for ld used by GCC... c:/mingw/mingw32/bin/ld.exe checking
>> >> if the linker (c:/mingw/mingw32/bin/ld.exe) is GNU ld... yes checking
>> >> for shared library run path origin... done checking for
>> >> CFPreferencesCopyAppValue... no checking for CFLocaleCopyCurrent...
>> >> no checking for GNU gettext in libc... no checking for iconv... yes
>> >> checking for working iconv... yes checking for GNU gettext in
>> >> libintl... no checking whether to use NLS... no Using user-specified
>> >> proj
>> >> directory: /c/projects/pg/pg90 checking proj_api.h usability... yes
>> >> checking proj_api.h presence... yes checking for proj_api.h... yes
>> >> checking for pj_get_release in -lproj... yes checking json/json.h
>> >> usability... no checking json/json.h presence... no checking for
>> >> json/json.h... no checking for json_object_get in -ljson... no
>> >> TOPOLOGY: Topology support requested
>> >> checking for GDAL >= 1.6.0... found
>> >> checking for GDALFPolygonize in -lgdal... no
>> >> configure: creating ./config.status
>> >> config.status: creating GNUmakefile
>> >> config.status: creating extensions/Makefile
>> >> config.status: creating extensions/postgis/Makefile
>> >> config.status: creating extensions/postgis/postgis.control
>> >> config.status: creating extensions/postgis_topology/Makefile
>> >> extensions/postgis_topology/postgis_topology.control
>> >> config.status: creating liblwgeom/Makefile
>> >> config.status: creating liblwgeom/cunit/Makefile
>> >> config.status: creating liblwgeom/liblwgeom.h
>> >> config.status: creating libpgcommon/Makefile
>> >> config.status: creating libpgcommon/cunit/Makefile
>> >> config.status: creating postgis/Makefile
>> >> config.status: creating postgis/sqldefines.h
>> >> config.status: creating loader/Makefile
>> >> config.status: creating loader/cunit/Makefile
>> >> config.status: creating topology/Makefile
>> >> config.status: creating regress/Makefile
>> >> config.status: creating doc/Makefile
>> >> config.status: creating doc/Makefile.comments
>> >> config.status: creating doc/html/image_src/Makefile
>> >> config.status: creating utils/Makefile
>> >> config.status: creating java/jdbc/Makefile
>> >> config.status: creating raster/Makefile
>> >> config.status: creating raster/rt_core/Makefile
>> >> config.status: creating raster/rt_pg/Makefile
>> >> config.status: creating raster/loader/Makefile
>> >> config.status: creating raster/test/Makefile
>> >> config.status: creating raster/test/core/Makefile
>> >> config.status: creating raster/test/regress/Makefile
>> >> config.status: creating raster/scripts/Makefile
>> >> config.status: creating raster/scripts/python/Makefile
>> >> config.status: creating postgis_config.h
>> >> config.status: postgis_config.h is unchanged
>> >> config.status: creating raster/raster_config.h
>> >> config.status: raster/raster_config.h is unchanged
>> >> config.status: executing libtool commands
>> >> config.status: executing po-directories commands
>> >>   PostGIS is now configured for i686-pc-mingw32
>> >>  -------------- Compiler Info -------------
>> >>   C compiler:           gcc -g -O2
>> >>   C++ compiler:         g++ -g -O2
>> >>  -------------- Dependencies --------------
>> >>   GEOS config:          /c/projects/geos/rel-3.3.2/bin/geos-config
>> >>   GEOS version:         3.3.2
>> >>   GDAL config:          /c/projects/gdal/rel-1.9.0/bin/gdal-config
>> >>   GDAL version:         1.9.0
>> >>   PostgreSQL config:    /c/projects/pg/pg90/bin/pg_config
>> >>   PostgreSQL version:   PostgreSQL 9.1.2
>> >>   PROJ4 version:        46
>> >>   Libxml2 config:
>> >> /c/projects/libxml/libxml2-2.7.8release/bin/xml2-config
>> >>   Libxml2 version:      2.7.8
>> >>   JSON-C support:       no
>> >>   PostGIS debug level:  0
>> >>   Perl:                 /bin/perl
>> >>  --------------- Extensions ---------------
>> >>   PostGIS Raster:       enabled
>> >>   PostGIS Topology:     enabled
>> >>  -------- Documentation Generation --------
>> >>   xsltproc:
>> >>   xsl style sheets:
>> >>   dblatex:
>> >>   convert:              /c/Windows/system32/convert
>> >>   mathml2.dtd:
>> >> http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
>> >> > Of Paul Ramsey
>> >> > Sent: Tuesday, February 28, 2012 4:46 PM
>> >> > Environment, tool-chain? ./autogen, ./configure?
>> >> > P
>> >> > On Tue, Feb 28, 2012 at 1:43 PM, Pierre Racine
>> >> > wrote:
>> >> > > Hi,
>> >> > > I just updated my geos to this one:
>> >> > > http://download.osgeo.org/geos/geos-3.3.2.tar.bz2
>> >> > > (the svn trunk does not compile) and still PostGIS complain with like this:
>> >> > > /bin/sh ../libtool --mode=compile gcc -g -O2  -DDLL_EXPORT -DPIC
>> >> > > -Wall -Wmissing-prototypes -I/c/projects/geos/rel-3.3.2/include
>> >> > > -I/c/proje cts/pg/pg90/include -c -o lwgeom_geos.lo lwgeom_geos.c
>> >> > > libtool: compile:  gcc -g -O2 -DDLL_EXPORT -DPIC -Wall
>> >> > > -I/c/projects/pg/pg90/inclu de -c lwgeom_geos.c  -DDLL_EXPORT
>> >> > > -DPIC -o .libs/lwgeom_geos.o
>> >> > > lwgeom_geos.c: In function `lwgeom_snap':
>> >> > > lwgeom_geos.c:937: error: `POSTGIS_GEOS_VERSION' undeclared
>> >> > > (first use in this function)
>> >> > > lwgeom_geos.c:937: error: (Each undeclared identifier is reported
>> >> > > only once
>> >> > > lwgeom_geos.c:937: error: for each function it appears in.)
>> >> > > lwgeom_geos.c: In function `lwgeom_sharedpaths':
>> >> > > lwgeom_geos.c:1001: error: `POSTGIS_GEOS_VERSION' undeclared
>> >> > > lwgeom_geos.c: In function `LWGEOM2GEOS':
>> >> > > lwgeom_geos.c:265: warning: unreachable code at beginning of
>> >> > > switch statement
>> >> > > make[1]: *** [lwgeom_geos.lo] Error 1
>> >> > > make[1]: Leaving directory `/c/projects/postgis/liblwgeom'
>> >> > > make: *** [all] Error 1
>> >> > > _______________________________________________
>> >> > > postgis-devel mailing list
>> >> > > postgis-devel at postgis.refractions.net
>> >> > > http://postgis.refractions.net/mailman/listinfo/postgis-devel
