[postgis-devel] PostGIS compile problem
Paul Ramsey pramsey at opengeo.org
Tue Feb 28 16:44:55 PST 2012
Good (bad) news, this is actually happening everywhere in MinGW land,
I don't know why Regina didn't catch it last night.
P.
On Tue, Feb 28, 2012 at 4:40 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> And get on IRC
>> Put the contents of config.log into a pastebin
>> p
>> On Tue, Feb 28, 2012 at 4:33 PM, Pierre Racine
>> <Pierre.Racine at sbf.ulaval.ca> wrote:
>>> If I erase postgis_config.h it recreates it but still without any #define...
>>>> -----Original Message-----
>>>> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>>>> bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
>>>> Sent: Tuesday, February 28, 2012 7:24 PM
>>>> To: PostGIS Development Discussion
>>>> Subject: Re: [postgis-devel] PostGIS compile problem
>>>> I have the same errors, must be part of the process so some extent...
>>>> P.
>>>> On Tue, Feb 28, 2012 at 4:15 PM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
>>>> wrote:
>>>> > In config.log I get many line like below. I suspect I'm missing some update but
>>>> which one?
>>>> > conftest.c:20:28: ac_nonexistent.h: No such file or directory
>>>> > configure:10802: $? = 1
>>>> > configure: failed program was:
>>>> > | /* confdefs.h */
>>>> > | #define PACKAGE_NAME ""
>>>> > | #define PACKAGE_TARNAME ""
>>>> > | #define PACKAGE_VERSION ""
>>>> > | #define PACKAGE_STRING ""
>>>> > | #define PACKAGE_BUGREPORT ""
>>>> > | #define PACKAGE_URL ""
>>>> > | #define STDC_HEADERS 1
>>>> > | #define HAVE_SYS_TYPES_H 1
>>>> > | #define HAVE_SYS_STAT_H 1
>>>> > | #define HAVE_STDLIB_H 1
>>>> > | #define HAVE_STRING_H 1
>>>> > | #define HAVE_MEMORY_H 1
>>>> > | #define HAVE_STRINGS_H 1
>>>> > | #define HAVE_INTTYPES_H 1
>>>> > | #define HAVE_STDINT_H 1
>>>> > | #define HAVE_UNISTD_H 1
>>>> > | #define LT_OBJDIR ".libs/"
>>>> > | /* end confdefs.h.  */
>>>> > | #include <ac_nonexistent.h>
>>>> >> [mailto:postgis-devel- bounces at postgis.refractions.net] On Behalf Of
>>>> >> Paul Ramsey
>>>> >> Sent: Tuesday, February 28, 2012 7:09 PM
>>>> >> None. It's supposed to be generated from postgis_config.h.in at
>>>> >> ./configure time
>>>> >> P.
>>>> >> On Tue, Feb 28, 2012 at 4:07 PM, Pierre Racine
>>>> >> wrote:
>>>> >> > Nothing is defined in my postgis_config.h
>>>> >> > Any idea why?
>>>> >> >> Of Paul Ramsey
>>>> >> >> Sent: Tuesday, February 28, 2012 7:06 PM
>>>> >> >> It should be defined in postgis_config.h
>>>> >> >> On Tue, Feb 28, 2012 at 4:04 PM, Pierre Racine
>>>> >> >> wrote:
>>>> >> >> > Still can't compile. Where should be defined this
>>>> POSTGIS_GEOS_VERSION?
>>>> >> >> Can't find it...
>>>> >> >> >> Behalf Of Pierre Racine
>>>> >> >> >> Sent: Tuesday, February 28, 2012 4:52 PM
>>>> >> >> >> $ ./autogen.sh
>>>> >> >> >> * Running /mingw/bin/libtoolize (2.2.10)
>>>> >> >> >>    OPTIONS = --force --copy --install
>>>> >> >> >> libtoolize: putting auxiliary files in `.'.
>>>> >> >> >> libtoolize: copying file `./config.guess'
>>>> >> >> >> libtoolize: copying file `./config.sub'
>>>> >> >> >> libtoolize: copying file `./install-sh'
>>>> >> >> >> libtoolize: copying file `./ltmain.sh'
>>>> >> >> >> libtoolize: putting macros in AC_CONFIG_MACRO_DIR, `macros'.
>>>> >> >> >> libtoolize: copying file `macros/libtool.m4'
>>>> >> >> >> libtoolize: copying file `macros/ltoptions.m4'
>>>> >> >> >> libtoolize: copying file `macros/ltsugar.m4'
>>>> >> >> >> libtoolize: copying file `macros/ltversion.m4'
>>>> >> >> >> libtoolize: copying file `macros/lt~obsolete.m4'
>>>> >> >> >> libtoolize: Consider adding `-I macros' to ACLOCAL_AMFLAGS in
>>>> >> Makefile.am.
>>>> >> >> >> * Running /mingw/bin/aclocal (1.11)
>>>> >> >> >> * Running /mingw/bin/autoconf (2.65)
>>>> >> >> >> Now you are ready to run './configure'
>>>> >> >> >> $ ./configure --with-xml2config=/c/projects/libxml/libxml2-
>>>> >> >> >> 2.7.8release/bin/xml2-config --with-
>>>> >> >> >> pgconfig=/c/projects/pg/pg90/bin/pg_config - -with-
>>>> >> >> >> geosconfig=/c/projects/geos/rel-3.3.2/bin/geos-config --with-
>>>> >> >> >> projdir=/c/projects/pg/pg90
>>>> >> >> >> --with-gdalconfig=/c/projects/gdal/rel-1.9.0
>>>> >> >> >> /bin/gdal-config
>>>> >> >> >> checking build system type... i686-pc-mingw32 checking host
>>>> >> >> >> system
>>>> >> type...
>>>> >> >> >> i686-pc-mingw32 checking how to print strings... printf
>>>> >> >> >> checking for gcc... gcc checking whether the C compiler
>>>> >> >> >> works... yes checking for C compiler default output file
>>>> >> >> >> name... a.exe checking for suffix of executables... .exe
>>>> >> >> >> checking whether we are cross compiling... no checking for
>>>> >> >> >> suffix of object files... o checking whether we are using the
>>>> >> >> >> GNU C compiler... yes checking whether gcc
>>>> >> accepts -g...
>>>> >> >> >> yes checking for gcc option to accept ISO C89... none needed
>>>> >> >> >> checking for a sed that does not truncate output... /bin/sed
>>>> >> >> >> checking for grep that handles long lines and -e... /bin/grep
>>>> >> >> >> checking for egrep... /bin/grep -E
>>>> >> >> checking for fgrep... /bin/grep -F checking for ld used by gcc...
>>>> >> >> >> c:/mingw/mingw32/bin/ld.exe checking if the linker
>>>> >> >> >> (c:/mingw/mingw32/bin/ld.exe) is GNU ld... yes checking for
>>>> >> >> >> BSD- or
>>>> >> >> >> MS- compatible name lister (nm)... /mingw/bin/nm checking the
>>>> >> >> >> name lister
>>>> >> >> >> (/mingw/bin/nm) interface... BSD nm checking whether ln -s works...
>>>> >> >> >> yes checking the maximum length of command line arguments...
>>>> >> >> >> 8192 checking whether the shell understands some XSI
>>>> >> >> >> constructs... yes checking whether the shell understands
>>>> >> >> >> "+="... yes checking for c:/mingw/mingw32/bin/ld.exe option to
>>>> >> >> >> reload object files... -r checking for objdump... objdump
>>>> >> >> >> checking how to recognize dependent libraries... file_magic
>>>> >> >> >> ^x86 archive import|^x86 DLL checking for ar... ar checking for
>>>> >> >> >> strip... strip checking for ranlib... ranlib checking for
>>>> >> >> >> gawk... gawk checking command to parse /mingw/bin/nm output
>>>> >> >> >> from gcc object... ok checking how to run the C preprocessor...
>>>> >> >> >> gcc -E checking for ANSI C header files... yes checking for
>>>> >> >> >> sys/types.h... yes checking for sys/stat.h... yes checking for
>>>> >> >> >> stdlib.h... yes checking for string.h... yes checking for
>>>> >> >> >> memory.h... yes checking for strings.h... yes checking for
>>>> >> >> >> inttypes.h... yes checking for stdint.h... yes checking for
>>>> >> >> >> unistd.h... yes checking for dlfcn.h... no
>>>> >> checking for objdir...
>>>> >> >> >> .libs checking if gcc supports -fno-rtti -fno-exceptions... no
>>>> >> >> >> checking for gcc option to produce PIC... -DDLL_EXPORT -DPIC
>>>> >> >> >> checking if gcc PIC flag -DDLL_EXPORT -DPIC works... yes
>>>> >> >> >> checking if gcc static flag -static works... yes checking if
>>>> >> >> >> gcc supports -c -o file.o... yes checking if gcc supports -c -o file.o...
>>>> >> >> >> (cached) yes checking whether the gcc linker
>>>> >> >> >> (c:/mingw/mingw32/bin/ld.exe) supports shared libraries... yes
>>>> >> >> >> checking whether -lc should be explicitly linked in... yes
>>>> >> >> >> checking dynamic linker characteristics... Win32 ld.exe
>>>> >> >> >> checking how to hardcode library paths into programs...
>>>> >> >> >> immediate checking whether stripping libraries is possible...
>>>> >> >> >> yes checking if libtool supports shared libraries... yes checking whether
>>>> to build shared libraries...
>>>> >> >> >> yes checking whether to build static libraries... yes checking for gcc...
>>>> >> >> (cached) gcc checking whether we are using the GNU C compiler...
>>>> >> >> >> (cached) yes checking whether gcc accepts -g... (cached) yes
>>>> >> >> >> checking for gcc option to accept ISO C89... (cached) none
>>>> >> >> >> needed checking how to run the C preprocessor... gcc -E
>>>> >> >> >> checking for
>>>> >> >> >> g++... g++ checking whether we are using the GNU C++ compiler...
>>>> >> >> >> yes checking whether g++ accepts -g... yes checking how to run
>>>> >> >> >> the
>>>> >> >> >> C++ preprocessor... g++ -E checking
>>>> >> >> for ld used by g++...
>>>> >> >> >> (c:/mingw/mingw32/bin/ld.exe) is GNU ld... yes checking whether
>>>> >> >> >> the
>>>> >> >> >> g++ linker
>>>> >> >> >> checking for g++ option to produce PIC... -DDLL_EXPORT -DPIC
>>>> >> >> >> checking if g++ PIC flag - DDLL_EXPORT -DPIC works... yes
>>>> >> >> >> checking if g++ static flag -static works... yes checking if
>>>> >> >> >> g++ supports -c -o file.o... yes
>>>> >> >> checking if g++ supports -c -o file.o...
>>>> >> >> >> (cached) yes checking whether the g++ linker
>>>> >> >> >> immediate checking for ant... no checking if g++ supports
>>>> >> >> >> -Wall... yes checking if
>>>> >> >> >> g++ supports -
>>>> >> >> Wmissing-prototypes... yes checking if g++ supports -ffloat-store...
>>>> >> >> >> yes checking for flex... flex checking lex output file root...
>>>> >> >> >> lex.yy checking lex library... -lfl checking whether yytext is
>>>> >> >> >> a pointer... yes checking
>>>> >> >> for bison...
>>>> >> >> >> bison -y checking ieeefp.h usability... no checking ieeefp.h
>>>> >> >> >> presence... no checking for ieeefp.h... no checking termios.h
>>>> >> >> >> usability... no checking termios.h presence... no checking for
>>>> >> >> >> termios.h... no checking for vasprintf... no checking for asprintf...
>>>> >> >> >> no checking for _LARGEFILE_SOURCE value needed for large files...
>>>> >> >> >> unknown
>>>> >> >> checking for perl... /bin/perl checking for convert...
>>>> >> >> >> /c/Windows/system32/convert checking for xsltproc... no
>>>> >> >> >> checking for
>>>> >> >> xmllint...
>>>> >> >> >> /c/projects/pg/pg90/bin/xmllint checking for dblatex... no
>>>> >> >> >> checking CUnit/CUnit.h usability... yes checking CUnit/CUnit.h
>>>> >> >> >> presence... yes checking for CUnit/CUnit.h... yes checking for
>>>> >> >> >> CU_initialize_registry in -lcunit... yes checking iconv.h
>>>> >> >> >> usability... yes checking iconv.h presence... yes checking for
>>>> >> >> >> iconv.h... yes checking for libiconv_open in -
>>>> >> >> liconv... yes checking for iconvctl...
>>>> >> >> >> no checking for libiconvctl... no Using user-specified pg_config file:
>>>> >> >> >> /c/projects/pg/pg90/bin/pg_config checking PostgreSQL version...
>>>> >> >> >> PostgreSQL
>>>> >> >> >> 9.1.2 checking libpq-fe.h usability... yes checking libpq-fe.h
>>>> >> >> >> presence... yes checking for libpq-fe.h... yes checking for
>>>> >> >> >> PQserverVersion in -lpq... yes Using user-specified xml2-config file:
>>>> >> >> >> /c/projects/libxml/libxml2- 2.7.8release/bin/xml2-config
>>>> >> >> >> checking libxml/tree.h usability... yes checking libxml/tree.h presence...
>>>> >> >> >> yes checking for libxml/tree.h... yes checking libxml/parser.h
>>>> >> >> >> usability... yes checking libxml/parser.h presence... yes
>>>> >> >> >> checking for libxml/parser.h... yes checking libxml/xpath.h usability...
>>>> >> >> >> yes checking libxml/xpath.h presence... yes checking for
>>>> >> >> >> libxml/xpath.h... yes checking libxml/xpathInternals.h usability...
>>>> >> >> >> yes checking libxml/xpathInternals.h presence... yes checking
>>>> >> >> >> for libxml/xpathInternals.h... yes checking for xmlInitParser
>>>> >> >> >> in -lxml2... yes Using
>>>> >> >> user-specified geos-config file:
>>>> >> >> >> checking GEOS version... 3.3.2
>>>> >> >> >> checking geos_c.h usability... yes checking geos_c.h presence...
>>>> >> >> >> yes checking for geos_c.h... yes checking for initGEOS in
>>>> >> >> >> -lgeos_c... yes checking whether make sets
>>>> >> >> $(MAKE)...
>>>> >> >> >> yes checking for a BSD-compatible install... /bin/install -c
>>>> >> >> >> checking for a thread- safe mkdir -p... /bin/mkdir -p checking
>>>> >> >> >> whether NLS is requested... yes checking for msgfmt... no
>>>> >> >> >> checking for
>>>> >> gmsgfmt... :
>>>> >> >> >> checking for xgettext... no
>>>> >> >> >> checking for msgmerge... no
>>>> >> >> >> checking for ld used by GCC... c:/mingw/mingw32/bin/ld.exe
>>>> >> >> >> checking if the linker (c:/mingw/mingw32/bin/ld.exe) is GNU ld...
>>>> >> >> >> yes checking for shared library run path origin... done
>>>> >> >> >> checking for CFPreferencesCopyAppValue... no checking for
>>>> >> CFLocaleCopyCurrent...
>>>> >> >> >> no checking for GNU gettext in libc... no checking for iconv...
>>>> >> >> >> yes checking for working iconv... yes checking for GNU gettext
>>>> >> >> >> in libintl... no checking whether to use NLS... no Using
>>>> >> >> >> user-specified proj
>>>> >> >> >> directory: /c/projects/pg/pg90 checking proj_api.h usability...
>>>> >> >> >> yes checking proj_api.h presence... yes checking for proj_api.h...
>>>> >> >> >> yes checking for pj_get_release in -lproj... yes checking
>>>> >> >> >> json/json.h usability... no checking json/json.h presence... no
>>>> >> >> >> checking for json/json.h... no checking for json_object_get in
>>>> >> >> >> -ljson... no
>>>> >> >> >> TOPOLOGY: Topology support requested checking for GDAL >= 1.6.0...
>>>> >> >> >> found checking for GDALFPolygonize in -lgdal... no
>>>> >> >> >> configure: creating ./config.status
>>>> >> >> >> config.status: creating GNUmakefile
>>>> >> >> >> config.status: creating extensions/Makefile
>>>> >> >> >> config.status: creating extensions/postgis/Makefile
>>>> >> >> >> config.status: creating extensions/postgis/postgis.control
>>>> >> >> >> config.status: creating extensions/postgis_topology/Makefile
>>>> >> >> >> extensions/postgis_topology/postgis_topology.control
>>>> >> >> >> config.status: creating liblwgeom/Makefile
>>>> >> >> >> config.status: creating liblwgeom/cunit/Makefile
>>>> >> >> >> config.status: creating liblwgeom/liblwgeom.h
>>>> >> >> >> config.status: creating libpgcommon/Makefile
>>>> >> >> >> config.status: creating libpgcommon/cunit/Makefile
>>>> >> >> >> config.status: creating postgis/Makefile
>>>> >> >> >> config.status: creating postgis/sqldefines.h
>>>> >> >> >> config.status: creating loader/Makefile
>>>> >> >> >> config.status: creating loader/cunit/Makefile
>>>> >> >> >> config.status: creating topology/Makefile
>>>> >> >> >> config.status: creating regress/Makefile
>>>> >> >> >> config.status: creating doc/Makefile
>>>> >> >> >> config.status: creating doc/Makefile.comments
>>>> >> >> >> config.status: creating doc/html/image_src/Makefile
>>>> >> >> >> config.status: creating utils/Makefile
>>>> >> >> >> config.status: creating java/jdbc/Makefile
>>>> >> >> >> config.status: creating raster/Makefile
>>>> >> >> >> config.status: creating raster/rt_core/Makefile
>>>> >> >> >> config.status: creating raster/rt_pg/Makefile
>>>> >> >> >> config.status: creating raster/loader/Makefile
>>>> >> >> >> config.status: creating raster/test/Makefile
>>>> >> >> >> config.status: creating raster/test/core/Makefile
>>>> >> >> >> config.status: creating raster/test/regress/Makefile
>>>> >> >> >> config.status: creating raster/scripts/Makefile
>>>> >> >> >> config.status: creating raster/scripts/python/Makefile
>>>> >> >> >> config.status: creating postgis_config.h
>>>> >> >> >> config.status: postgis_config.h is unchanged
>>>> >> >> >> config.status: creating raster/raster_config.h
>>>> >> >> >> config.status: raster/raster_config.h is unchanged
>>>> >> >> >> config.status: executing libtool commands
>>>> >> >> >> config.status: executing po-directories commands
>>>> >> >> >>   PostGIS is now configured for i686-pc-mingw32
>>>> >> >> >>  -------------- Compiler Info -------------
>>>> >> >> >>   C compiler:           gcc -g -O2
>>>> >> >> >>   C++ compiler:         g++ -g -O2
>>>> >> >> >>  -------------- Dependencies --------------
>>>> >> >> >>   GEOS config:
>>>> >> >> >>   GEOS version:         3.3.2
>>>> >> >> >>   GDAL config:
>>>> >> >> >> /c/projects/gdal/rel-1.9.0/bin/gdal-config
>>>> >> >> >>   GDAL version:         1.9.0
>>>> >> >> >>   PostgreSQL config:    /c/projects/pg/pg90/bin/pg_config
>>>> >> >> >>   PostgreSQL version:   PostgreSQL 9.1.2
>>>> >> >> >>   PROJ4 version:        46
>>>> >> >> >>   Libxml2 config:
>>>> >> >> >> /c/projects/libxml/libxml2-2.7.8release/bin/xml2-config
>>>> >> >> >>   Libxml2 version:      2.7.8
>>>> >> >> >>   JSON-C support:       no
>>>> >> >> >>   PostGIS debug level:  0
>>>> >> >> >>   Perl:                 /bin/perl
>>>> >> >> >>  --------------- Extensions ---------------
>>>> >> >> >>   PostGIS Raster:       enabled
>>>> >> >> >>   PostGIS Topology:     enabled
>>>> >> >> >>  -------- Documentation Generation --------
>>>> >> >> >>   xsltproc:
>>>> >> >> >>   xsl style sheets:
>>>> >> >> >>   dblatex:
>>>> >> >> >>   convert:              /c/Windows/system32/convert
>>>> >> >> >>   mathml2.dtd:
>>>> >> >> >> http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
>>>> >> >> >> > Sent: Tuesday, February 28, 2012 4:46 PM
>>>> >> >> >> > Environment, tool-chain? ./autogen, ./configure?
>>>> >> >> >> > P
>>>> >> >> >> > On Tue, Feb 28, 2012 at 1:43 PM, Pierre Racine
>>>> >> >> >> > wrote:
>>>> >> >> >> > > Hi,
>>>> >> >> >> > > I just updated my geos to this one:
>>>> >> >> >> > > http://download.osgeo.org/geos/geos-3.3.2.tar.bz2
>>>> >> >> >> > > (the svn trunk does not compile) and still PostGIS complain
>>>> >> >> >> > > with like
>>>> >> this:
>>>> >> >> >> > > /bin/sh ../libtool --mode=compile gcc -g -O2  -DDLL_EXPORT
>>>> >> >> >> > > -DPIC -Wall -Wmissing-prototypes
>>>> >> >> >> > > -I/c/projects/geos/rel-3.3.2/include
>>>> >> >> >> > > -I/c/proje cts/pg/pg90/include -c -o lwgeom_geos.lo
>>>> >> >> >> > > lwgeom_geos.c
>>>> >> >> >> > > libtool: compile:  gcc -g -O2 -DDLL_EXPORT -DPIC -Wall
>>>> >> >> >> > > -Wmissing-prototypes -I/c/projects/geos/rel-3.3.2/include
>>>> >> >> >> > > -I/c/projects/pg/pg90/inclu de -c lwgeom_geos.c
>>>> >> >> >> > > -DDLL_EXPORT -DPIC -o .libs/lwgeom_geos.o
>>>> >> >> >> > > lwgeom_geos.c: In function `lwgeom_snap':
>>>> >> >> >> > > lwgeom_geos.c:937: error: `POSTGIS_GEOS_VERSION' undeclared
>>>> >> >> >> > > (first use in this function)
>>>> >> >> >> > > lwgeom_geos.c:937: error: (Each undeclared identifier is
>>>> >> >> >> > > reported only once
>>>> >> >> >> > > lwgeom_geos.c:937: error: for each function it appears in.)
>>>> >> >> >> > > lwgeom_geos.c: In function `lwgeom_sharedpaths':
>>>> >> >> >> > > lwgeom_geos.c:1001: error: `POSTGIS_GEOS_VERSION'
>>>> >> >> >> > > undeclared (first use in this function)
>>>> >> >> >> > > lwgeom_geos.c: In function `LWGEOM2GEOS':
>>>> >> >> >> > > lwgeom_geos.c:265: warning: unreachable code at beginning
>>>> >> >> >> > > of switch statement
>>>> >> >> >> > > make[1]: *** [lwgeom_geos.lo] Error 1
>>>> >> >> >> > > make[1]: Leaving directory `/c/projects/postgis/liblwgeom'
>>>> >> >> >> > > make: *** [all] Error 1
>>>> >> >> >> > > _______________________________________________
>>>> >> >> >> > > postgis-devel mailing list
>>>> >> >> >> > > postgis-devel at postgis.refractions.net
>>>> >> >> >> > > http://postgis.refractions.net/mailman/listinfo/postgis-dev
>>>> >> >> >> > > el
>>>> >> >> >> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
