[postgis-devel] [PostGIS] #1628: Can't configure anymore again on mingw
PostGIS trac at osgeo.org
Tue Feb 28 20:22:30 PST 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 FWIW my script looks something like this
 export GEOS_VER=3.3.3SVN_345
 export GDAL_VER=1.9.0_345
 export XML_VER=2.7.8
 export PROJSO="libproj.dll"
 export PROJ_LIB=/c/projects/postgis/pg/pg84/share/contrib/postgis/proj
 export GDAL_DATA=/c/projects/gdal/rel-${GDAL_VER}/share/gdal
 export JSON_VER=0.9_345
 ./configure  --prefix=/c/projects/pg/pg${PG_VER} --with-
 gdalconfig=/c/projects/gdal/rel-${GDAL_VER}/bin/gdal-config --with-
 jsondir=/c/projects/json-c/rel-${JSON_VER} --with-
 xml2config=/c/projects/libxml/libxml2-${XML_VER}release/bin/xml2-config
 --with-pgconfig=/c/projects/pg/pg${PG_VER}/bin/pg_config --with-
 geosconfig=/c/projects/geos/rel-${GEOS_VER}/bin/geos-config --with-
 projdir=/c/projects/proj/rel-4.6.1 --with-gettext=no  --with-gui --with-
 topology
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1628#comment:2>
