[postgis-devel] circular dependency in doc/ ?
Sandro Santilli strk at keybit.net
Wed Feb 29 02:00:45 PST 2012
On Tue, Feb 28, 2012 at 08:33:58PM +0100, Sandro Santilli wrote:
> On Tue, Feb 28, 2012 at 11:22:27AM -0800, Chris Hodgson wrote:
> > So I guess I can support the --nonet as the default, would be nice
> > if there was an easy option to allow building without --nonet for a
> > quick fix - quick as in effort, not elapsed time :)
> An environment variable, maybe. Like RUNTESTFLAGS for "make check".
> Should check if xsltproc supports a switch to disable --nonet in
> order to override the default...
In r9343 we have support for a XSLTPROCFLAGS. but I found no way
to disable a --nonet switch so we need something smarter.
What we could do is haveing XSLTPROCFLAGS default to --nonet if nothing
is given, which means you can disable it using something like:
   make html XSLTPROCFLAGS=
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
